Okay, I attached a picture of the manual, owner's manual that is. Where it says to drain the Front Mission case and shows an arrow pointing to a drain plug and it shows right below it the drain plugs for the rear Mission case my question is when I fill from the main rear fill plug,w I'll it fill both? Because looking around I am not seeing any fill port on the front mission.
Thanks,
Jason Schiefelbein
Kranzburg, SD
Thanks,
Jason Schiefelbein
Kranzburg, SD
