New member here... I'm trying to do a complete maintenance service on my dad’s B1550 HST Kubota. It has not been serviced in over 3 years since he passed away and I want to get it in tip top shape. So far I have changed the oil, oil filter, fuel filter, replaced the gear oil in the front axle, greased all the grease points and replaced the coolant. I am currently trying to replace the hydraulic transmission fluid.
I found 3 plugs on the bottom of the tracktor; 1 right under the front PTO and 2 on each side of the rear axle. When removed the HST oil filter I can tell that not all the hydraulic fluid has been drained. Also, the HST dipstick shows a considerable amount of hydraulic fluid still in the transmission. Does anyone know of anymore drain plugs for the transmission fluid? Any suggestions? Thanks!
Kevin
Kevin
