B series vs. L series.
SRG
B8200D 4WD........ JD 870, FWA, 300x FEL.......... JD 797, 72" Z-Trak
Jul 15, 2017
490
N. IL
I'm window shopping now, for an inevitable purchase, in the near future. I need/want a FEL around and sourcing one for my B8200 (BF-300A FEL) is near impossible (if anyone has a line on a complete FEL, please PM me).
Anyway, I've been researching different models (used). Comparing pricing vs. features and what I've noticed is that B series machines seem to cost the same, or more than their L series siblings. Why is that? The L is a heavier machine at comparable horsepower ratings, from what I've gathered.
Ex; L2800 (28-30hp) with LA463 FEL's seem to be in the $12.5-14K range with really low hours. Comparable B series (ex; B2920) with the same HP ratings (29hp) and an LA364 are priced right around the same, if not more.
What's the physical differences between them? What makes the L an L and the B a B?
mickeyd
Mar 21, 2014
1,192
Guin, AL
The L series has a bigger and heavier frame. The wider stance gives better footing on hills and the added weight gives better traction.
SRG
Jul 15, 2017
490
N. IL
Okay, so yeah size and weight is a given, which is what brought me here. I'm curious why they can be found for the same price as the smaller B series machines when they have more steel (weight) and larger wheels and tires (usually).
6,712
I think part of the price is available options between the B and L series. The B series has more available options and features when compared to the L models in the same horse power class. The smaller L models are economy models and have less available features like shuttle shift, mid mount mower, or cab options.
Where the B model has an available mid mount mower, shuttle shift, and cab options.
5,248
1,923
The B series is built similar to a BIG lawn mower, with a "frame".
The L series is a real tractor. No frame. The transmission IS the frame, like real tractors are supposed to be built. MUCH easier to work on, BTW.
Both are good tractors. The B series doesn't have the lifting capacity obviously, so if that is a concern....
No belly mower option for the new L series that I know of. B series will accept a belly deck no problem. It's designed for it from the get-go, like a big lawn mower.
L series will accept a nice backhoe. B series will too but it's smaller and won't dig nearly as much, even with the same horsepower rating.
SRG
Jul 15, 2017
490
N. IL
Found a 2010 L2800DT 'Extra Power' at a dealer not too terribly far from me. I'm gonna be contacting them about trading my B8200D and financing the L. See if we can work something out. Though I've a feeling they will low ball me big time on my current machine (which i really wouldn't mind keeping anyway, it's a good machine).
I have a zero turn that i mow with around here. It gets the job done pretty quick. No real need for a belly mower. I'm more interested in the weight and lifting capacity.
