He fellows, I'm in the process of converting from a dynamo to 60A alternator on my B7200. I was able to locate all the necessary mounting bracket and parts. These alternators were an option on the B6200, B7200, B8200, & B9200 tractors, and standard on European models (I believe). Kubota made kits for a while, but they've long since been discontinued.
The only issue I've run into is with the alternator mounting bracket itself. It mounts to the cylinder head in two locations. The first is engine eye-lift location. No issues here. The second is right on top of a cylinder head bolt. Please see attached image.
It's as if there is supposed to be one of those combination bolt/stud fasteners there, but it's just a regular head bolt. I've searched and cannot find one in the kubota parts manual either. Apparently these head bolts are a non-standard M9x1.25 size.
Anyone think it's possible to weld a threaded stud on the top of the head bolt? I'm open other ideas as well.
Thanks,
Brandon
Thanks,
Brandon
