B-7800 Led headlights?
5,357
Dave, I kind of disagree, some models do really great changing just the bulb, there are some pretty intense LED's out now.
But yes some still suck with new LED's in them.
Speedybon, If you post some pictures of the Lamps you have I might be able to lead you in the right direction if available.
boz1989
B2910 fel 60 mmm, Land Pride rb1572
Jun 10, 2015
269
Portland, MI
If I remember correctly, it's an 1156 bulb, sorry, I don't remember what led bulb I used. I do know it's a lot brighter than the original yellow things
Sent from my LGMP260 using Tapatalk
4,890
1,624
yeah, some of them I've done do just "ok" with led bulbs. others scatter the light so much that they are worthless. only way to know is to try; i've not done a 7800 yet
4,172
I was wondering if anybody has replace the Standard headlight with leds. Its a single element and if you knew the part number?
Speedy - I did a quick check and found part #66591-55630 for the OEM bulb only.
I've had some luck searching Part #'s, and finding references to "standard" auto bulbs. If boz is correct, 1156 is a common auto bulb type, and you should be able to find an LED version easily.
I did also see an 1156 reference for this P/N#. I think you'd want the LED version of these - do they look like your bulbs?:
https://powermowersales.com/Bulb-Kubota-66591-55630_p_201319.html
Just an LED example, might be able to find some at an auto parts store. Like Wolfman said, there's REALLY bright ones (these are 11W and 1,700 lumens):
https://www.amazon.com/LUYED-Extremely-Chipsets-Reverse-Brightest/dp/B01H54SP6O
But like Dave and lugbolt said it may or may not help a lot. My headlights are much better, but not great. I also didn't get really bright bulbs either....my wife says I'm a dim bulb sometimes.....:eek:
Speedybon
59
22
Arroyo Grande
Re: B-7800 Led headlights? 1156 works
So I replace with LEDs and its so much brighter and 1/2 amp compared a full amp. You guys have to try this if lighting is a concern. AUXITO 2600 Lumens 1156 LED Bulbs BA15S P21W 7506 LED Light Bulbs Replacement for Backup Reverse Light Bulb Tail Light 6000K White $15.99 from Amazon. WHAT A DIFFERENCE.:)
Speedybon
59
22
Arroyo Grande
I just tried the headlights at night and single 1156 bulb put out 189 lumens and the LED bulb are is putting out 2600 lumens. Also they seem to produce very little heat.
Hodgy
B7800, front blade, box blade, subsoiler & 3 PTH snowblower
Apr 19, 2019
126
9
I have been looking at my pitiful headlights on the B7800 and this thread has prompted me to buy some LED bulbs. Took me 10 minutes on Ebay to find some cheap offshore bulbs. I ordered both kinds, will see which are best. They will get here sometime in January or February, I will be good as I have spot lights on the cab.
3400 lumens, $6.74 CAD for two bulbs
https://www.ebay.ca/itm/1-Pair-1156-144SMD-BA15S-P21W-LED-Car-Turn-Signal-Light-Bulb-Canbus-White-12-24V/383276199272?hash=item593d0aad68:g:WMIAAOSwW89d1OH0&vxp=mtr
1200 lumens $2.10 CAD for two bulbs
https://www.ebay.ca/itm/1156-BA15S-P21W-3030-21SMD-LED-Car-Tail-Backup-Reverse-Light-Bulb-1200Lm-White/312863475801?hash=item48d81dc859&_trkparms=ispr%3D1&enc=AQAEAAADcKvsXIZtBqdkfsZsMtzFbFsbX3WcW5fmB%2Fx7ZbaZTyexq6HzUVdSwzRRpe8IJB%2BPgI9RQf%2Bdz2BxbDr5%2FB8ZHJxqkB1d8aQNFwDuQ5X50SV%2FaJ8WfJBQxSks55wByCA%2B1NYwxdqH2KK%2BX2GZ4CKULgpOXRGhohecSz1eX4OOIz4UnhWYeDiynmwvOvw%2FqOmEsnQqH7Y%2FGH8NuUL%2Bwu4%2B8GT25RpBolVrHrzd5mbVbrcEyPfY%2BsMXpTNUGxR5TnLw2jxG9Jv%2FtZnhvAR47gFGhn49PMaxP5SF1TyQ%2BeS8nCQ1pUO0TyMRm27KxVdxlfhXHuoumHgV6dIF4CWNMZmYN%2B6yzmJBnRqXmFgM%2Fy5wbM4XgliEdgvAYlbQg%2BH%2B9ePSbN7BOiLPzxMHb1PX1RwqQnr%2BYOfeP%2B7v%2B7JYXaxhbdJrGsTnBLRjEpNViISRfO9Lj4Mz3EYnCR3NHzh%2FvFpQh0%2BDN5A3gmWLGGAh%2Fiqi5aY3aRN432DQ0qPqKNsrSkO0S5nsJiSz94muvTaABF1tZIzslOYlk1l0MDsNwNN%2BEuKUt7sxd9Zp7aa%2F859YfAi%2FAnrXqt1ZCou0UfievDoEGUqrkQftYeMs0%2BY2aHS9nKUerG415Zh7hzekNeoQncpWqztuH635RybdwZh%2FlnegzYDUhYpNGPsdveLV%2FRtOGZ8ZBk3krwQBP7unS49By1xVog4rJ9I0UqC0rYFUvs7WBXAqgAIdyvih%2BCn6lg6A5LHw3voQ8IQC2saZEaXOWSnP18DQZsyjg0cUDX8vf5tgDPge%2FUgiLmhP6ysIhlwi9EWDo%2FHrFqgo%2FED54hVjvl%2FHqeeamDdpfehUalFEB2ZzgPkwtMW3b8dU35nU62nCT1hYCHQGxGmJdMVQ0i4rCSkS3pQ%2BR5dU16ip2Drmn8dU05CPS4MPo11GHbRnLKscOgjgpwCzl3EbglqQZBIEl7Ea62azlSRHGKmYvDFtrirxmqCuzjyrJ4jqD3hH6BHdK3kLYA78Je1IlU0U8bi9xfJhMBV0RGS20KB1sSrIKoYd%2FYZa%2FJmPkdGRPGCVm6JdCjl2ATYoZMCqKGVboh33rp3OU%2FuzRO3O7QxBPdWvrM4Q2VCYr%2Ff1VxQIOvOsy4dVo%2FDwtJRZdKJfZAhxX3EC4qsnzkq8dKHYxRE3dwTB%2FrpN5VA%3D&checksum=312863475801ce1d7132dc894fe993cfeb2577722540
3,129
I have been experimenting with LED replacement illumination in all sorts of applications in airplanes, boats, tractors, autos, etc etc and found that interchangeable, simple-replacement LED lamps are usually NOT the solve-all/end-all solutions people hope-for.
INcandescent lamps have a wide-spectrum of light energy they throw which, although wasteful of energy such as heat, usually fill-out the objects being observed. Thats a way of saying that LEDs may put out more measurable lumens but they dont always illuminate because of the narrow spectrum they emit.
Im not familiar with the B7800 OEM headlights, but the OEM headlights of my M4700 Kubota positively SUCK. They are dim-yellow and the only thing they are good for is to GLARE the backside of the Front End Loader bucket, fork, or frame, depending upon what tool is loaded. On top of that, they are a proprietary bulb which costs ridiculou$ly and is not commonly available. (The headlights are mounted down low as if no FEL was ever planned for the tractor, so the FEL blocks all forward-illumination of the lights. The local Kubota-dealer told me the reason they were built that way was because that was as high as the Japs could REACH!). :D
I solved my headlight problem by mounting an LED Light-Bar on top of the radiator-guard which places the HUGE amount of light above both the hood and the usual height of the FEL. Its the CATS MEOW for seeing at night!
Hodgy
Apr 19, 2019
126
9
I also have been experimenting with plug and play LED bulbs, mostly from off shore but some from the US. They have been placed in a 53' Ferguson, 97' Goldwing, 03' Tribute and a 05' Silverado with mixed results. LED's are great if you want to be seen but sometimes are not good for "seeing".
There are two LED light bars in my future for the B7800, both on the cab, one for the snowblower on the 3 PTH and one facing front. I have a light bar behind the grill on my Silverado and it is great.
Speedybon
59
22
Arroyo Grande
Believe me replace those 1156 bulbs with LEDs there is such a difference. For 15.00 dollars and a light bar. You will like it. AUXITO 2600 Lumens 1156 LED Bulbs
Hodgy
Apr 19, 2019
126
9
I looked at those before I bought mine. They are 1300 lumens per bulb for a total of 2600 lumens. They are probably very good bulbs.
Speedybon
59
22
Arroyo Grande
Re: B-7800 Led headlights? Be careful for the fit
I recommend AUXITO 2600 Lumens 1156 LED Bulbs BA15S P21W 7506 LED Light Bulbs Replacement for Backup Reverse Light Bulb Tail Light 6000K White
LUYED 2 X 1700 Lumens Extremely Bright 1156 4014 102-EX Chipsets 1156 1141 1003 7506 LED Bulbs THESE WILL NOT FIT THEY HIT THE LENS THEY ARE TO LONG. I will find another place for these. I do recommend replacing the factory bulbs 1156s with leds.
Butch
Kubota 2410, RC60-24B, FL1000- kubota hydrolic front snow blade- plug aerator
Sep 10, 2009
633
82
Rising Sun, MD
I replaced my OEM single element head light bulbs on the ole B2410 with some kick butt LEDs from Superbrightled.com. This site gives detailed info on the LED bulb. This will allow you to measure up your clearances in the OEM light housings. All you have to do is get the LED bulbs that put out the most light and still fit in the housing.
However.... (there seems to always be a however) LED bulbs are polarized. On mine I had to swap +/- leads to match the bulb center pin with the positive lead.
Other than that I just did a plug and play on the bulb swap... eazy peazy!
SidecarFlip
Banned
550
Well, if and hen the LED bulbs that Wolfman suggested I order show up, I'll post a test on them. Coming direct from China (via Sampan) so it will be a while I suspect.
Hodgy
Apr 19, 2019
126
9
I finally found some LED bulbs that were short enough to fit in the OEM housing. These do fit and are very bright. Just ordered two more before they go off market.
