I recently had an expensive 4WD trans repair, all new gears, bearings, and a new 4x4 / 2 WD shift lever replaced.
When I got the repair back all was nice and quiet , ie no trans gear rattle noise. Its been about 5 months since the repair, and now starting to get a loud rattle at idle from the trans or possibly the hydro drive shafts?
If the clutch is pushed in, all is nice and quiet.
I have an LA 402 loader and sub frame attached so its hard to see or gain access to much of anything under the tractor to diagnose the issue.
Everything seems to operate, ie no clutch slippage.
So any advice for how to locate and remediate the trans rattle, hoping that the repair done previously is still intact and not looking at more costly repairs.
The tractor is used intermittently so no hard use.
Thank you for any insights.
