B 7100 pilot bushing
olebmw
east coast of Kansas
I am putting a new pilot bushing and drive shaft in my tractor. There is a seal that installs after the dry bushing is in place. Since it is sealed, it seems like I should put some grease in there. Has anyone tried grease ? Thanks, Dan
handyman
Kubota B7100HST-E
Sep 18, 2009
452
Dayton,Tn.
I have a B7100 but hope vic or someone else jumps in to verify if I am right or not. :cool:If you will look real close in front of the clutch peddle (in front and low) there is a small hole and appx. 6 inches inside that hole on mine is a greese fitting for that bearing. I would put a recomended greese in it prior and aft. If yu havent taken it out yet you might want to try greese in that nipple might solve your problem;). Like I said hope someone else jumps in. handy
dusty-t
974
Mountforest Ontario
Hi Olebmw. Well I can tell you this. I put grease into the pilot bushing on my B7200 when I changed the clutch. When I pushed the propeller shaft into it the seal popped out. Sooo Just a little bit of grease on the end of the shaft to make it slide in easier. And the pilot bushing is made of some stuff that has lubricant in it. Some one with more tech knowhow can explain that.:D Dusty
traildust
B7610HST 4WD, LA352 FEL, Gearmore 2 Spool Top & Tilt Box Scraper
Jan 27, 2010
1,490
Phelan, California
If you are talking about the same location dusty just described then I would reccomend not putting any grease in there during the build up. (Not counting using the grease trick to get the old seal/bushing out)
I think extra grease during build up could migrate into the clutch works and cause slippage.
handyman
Kubota B7100HST-E
Sep 18, 2009
452
Dayton,Tn.
You are right need to keep my mouth shut sometimes. Guess had 1 to many thanks traildust and dusty for comming to my rescue.handy
dusty-t
974
Mountforest Ontario
Hell Handyman don't keep yer mouth shut, some real interesting stuff comes out of there sometimes. We can't be mechanical geniuse's all the time.:DDusty
traildust
Jan 27, 2010
1,490
Phelan, California
Handy, that is absolutely not true! I value all of your input and besides sometimes it can be slightly misleading what exactly the intentions are of everybody making a thread.
You are a great man with great advice. All of us truely appreciate ALL of your valuable input.
Scott
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
And the pilot bushing is made of some stuff that has lubricant in it..:D Dusty
Hi Dusty, If I have it right I think you may be referring to oil impregnated sintered bronze called "Oilite" bushing and are self lubricating .They are used a lot when there is not much space to fit a ball or roller Bearring or plces hidden away so not easy to lube regularly.
Dave
traildust
Jan 27, 2010
1,490
Phelan, California
Hi Dusty, If I have it right I think you mean, oil impregnated sintered bronze and are called "Oilite" bushing .They are used a lot when there is not much space to fit a ball or roller Bearring
Dave
Dave , our wonderful Man from Wales
Thanks for the technical update about Oilite - much appreciated :D
Scott
olebmw
Thanks for the replys. I'm still not clear if the seal is there to keep a small amount of grease in or dirt out. Maybe both. The new bushing,listed as a dry bushing, had a plastic or nylon liner in it. Hope I'm not replacing it again after a few hours.
dusty-t
974
Mountforest Ontario
Its to keep the dust out. You put a dab of grease on the end of shaft so that it slides past the seal and into the bushing easily. Plastic liner ? No clue.:D Dusty
B7100
Feb 11, 2010
422
Wales
With all this talk of plastic liner I am begining to think we are not refering to what I thought we were.If we are then then the plastic liner may be used as a "keep" to stop the impregnated oil dripping out and has to be removed before sliding in the the shaft:confused::confused:
dave
