auto braking
boneyard
f2100
May 6, 2015
baden pa
Have a F2100 that used to stop when I lifted my foot from forward pedal but now wants to keep going unless I push down on reverse. Would appreciate help if someone knows what controls this. tks
bxray
Bx25d
Dec 1, 2014
712
Cleveland, ohio
Sounds like it is not returning to the home or neutral position.
There should be a grease fitting.
Check under to see if there is dirt or other objects blocking it.
You should be able t o move it by hand when the tractor is off and feel the position.
There should be a sprong or two.
Ray
2,852
HEY you wouldn't happen to be or know old Boneyard Bill from down around Monaca ?
5,183
The other part that controls that is the dampener.
Might need to replace that if it's binding or just wore out. ;)
2,852
LOL,, he was a pretty good old boy,, I just thought I would ask he used to work or maybe owned a junk yard back in the day,,,, the man could find you almost any thing you needed for your hot rod
