searay
L3200, GMC Yukon, rotary cutter, pallet forks, box blade, post hole digger.
I just purchased a SpeeCo 3pt post hole digger but I didn't purchase the actual auger. Are some brands better then others or are they basically all the same. I also suspect that they have a universal connection between the post hole digger and the auger itself but would like someone to verify that.
To clarify further I'm looking for opinions on various brands of augers, when I use the term auger I'm referring only to the 4' by 6"-9"-12" diameter screw portion of the digger that screws itself into the ground and not the gearbox, pto shaft or bracket that attaches the unit to the tractor. I hope I have described what it is that I'm looking for better this time around. Thanks.
