Dan_R_42
B7100-D, w/ Sims Cab, B219 FEL, ARPS 70 Backhoe, Oversized R4 Tires, LX2610 Cab
Hello Guys, Can anyone provide me with the correct part # for the Attachment Pin I need for Kubota Drop Drawbar- BL6820 being used with Clevis Kit- LMX6800.
This drawbar is used for LX, L, MX, tractors.
I have not had much luck finding the correct Pin for this configuration. So far the Pins I have been told to use are too small a diameter to fit correctly in the drawbar. The Drawbar/Clevis hole diameter is 1.25" (1-1/4") The pin I have been told is the correct pin (99533-78250) for this setup is just under 1" (0.94").
To me, this pin seems a very sloppy fit, rattling around in the larger hole.
Thanks, Dan
Thanks, Dan
