Well, based on simple physics, 6" may put a lot of stress on the wheel bearings. Not that it won't work, but the bearings may have a much shorter life than normal.
If you are 4 foot stance now, and assume the housing is 2 feet wide, you have 1 foot on each side (I suspect a lot less than that). Adding 6" wheel spacers will add 50% more distance for stress on the bearings. (not that stress increases 50%, but significant...).
Basic issue is how much more from the bearings you are extending the wheels. If 6" spacers doubles the distance from the bearing, you are roughly doubling the stress on the bearings.
This is just an opinion, others may give different comments. I would say 2" or 3" spacers are probably ok, but 6" seems to be stretching the limits to me...
