Anyone see this casting break?
Uiucbsme
B2301hst
Jun 18, 2022
10
B2301 was parked with a mower attached to the three point hitch. I heard the mower drop as I walked away to get a drink. Saw hydraulic fluid everywhere. Lifted the seat and the casting immediately underneath was broken. The tractor has about 220 hours on it. I am at least the second owner. I’ve put about 100 hours on it. Anyone see a failure like this before.
BruceP
G5200H
Aug 7, 2016
852
370
Richmond, Vermont, USA
You asked...
I have seen tractor main-casting crack.... usually after being 'abused' such as carrying excessive weight in bucket at high speed over rough ground.
I have also seen 3-point arms snap off from tom-foolery.
Not suggesting you did anything wrong. Perhaps close inspection can reveal if there is any rust on the broken surfaces indicating it is an old crack which propagated.
NorthwoodsLife
Oct 15, 2021
1,228
1,213
Wisconsin
Ouch!
I was taught by my uncle in the 70's to never leave the 3 point, or loader, in the air when parked. Due to stress. I've never seen a finer example as to why.
Sorry, but you've taught so many of us with that damage.
And, this is why we don't road trip our tractor for 12 miles.
5,680
curious.. how does heavy bucket weight break the casting ??
Something tells me JBWeld will NOT be an option....has to be a LOT of time ,aka $$$ labour, involved in replacing the part ?
Uiucbsme
B2301hst
Jun 18, 2022
10
Having taken high level courses on failure mechanisms in engineering materials, I find it hard to believe that leaving the three point hitch up would cause this failure. Castings would tend to fail due to fatigue and lowering the hitch will (ever so slightly) cause more fatigue than leaving it up.
My guess is a faulty casting in order to break with so few hours on the tractor.
Uiucbsme
B2301hst
Jun 18, 2022
10
You asked...
The crack looks clean to me, but I haven’t gotten in too close yet.
5,233
Am I correct thinking thats the 3pt lift cylinder? Somomebody else posted a similar cylinder failure recently. Might have been a diffetent model tractor. My theory is the fracture is caused by hydraulic shock loads generated when transporting the mower in the raised positiin. Yours was probably compromised earlier and finslly gave up the ghost will sitting there.
Uiucbsme
B2301hst
Jun 18, 2022
10
It could be the lift cylinder. I don’t know the innards well enough to know.
6,610
Ouch!
I road trip my Case 730 12 miles pulling a round baler! May times, no damage.
hodge
Nov 19, 2010
2,950
514
Love, VA
I think that you are right, Dan. It looks like the lift cylinder casting, and it would most likely be fractured by internal pressure.
This didn't happen by leaving the mower up while going to get a drink.
Ulu, sorry this happened to you. Despite the reason for coming here, welcome to the forum!
3,585
Ouch!
Hahahah....No kidding.
Yesterday I was 'caught' behind this guy "abusing" his tractor..... ;)
5,680
Curious.looked it up, that casting is about $1300 Canadian, seems kinday easy to replace BUT the big issue would be to remove any casting bits out of the internal area.
