anyone know what this is
Kytim
B6000DT, B7100DT,Snowplow, RM360, Scoop, Cultivator, Carryall,Disk, plow
Aug 14, 2009
848
Western Ky
Its really hard, for me, to tell from that pic. have a better daytime pic?
kytim
firejunkie
Kubota Mx4700 4w/FEL, Modern Ag cutter,Dirt dog Box blade and Rake, Custom forks
Mar 19, 2011
81
greenwood, SC
pressure regulator, or anti siphon valve, or both.
hydrotroop
bossier city
ok here is my problem i was using tractor and it just stopped. i had injector pump rebuilt and now im not getting fuel to injector pump could this be my problem? i am not even getting fuel out of fluid bolt that goes to injector pump
hydrotroop
bossier city
ok it tries real hard to start and almost does then goes back to turning over normal then tries to start again then turns over normal and will do this till battery is dead any suggestions? could this still be the round pump? also how hard is it to rebuild
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,187
170
Hardisty, Alberta
If you loosen the bolt on the fuel fitting on the injection pump then crank the engine over you should have fuel squirt out. If you don't it would indicate that either the pump isn't working of there is a restriction preventing fuel getting to it.
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
Are you saying you had the fuel injection pump rebuilt?
If so I am curious to know what tests were done and who told you the pump was at fault for you to get it rebuilt.I find it hard to grasp why one of the most expensive proceedures was undertaken and the fault has not been rectified.Any lack of fuel ought have been found first!
fj40dave
Sep 24, 2009
425
257
Yelm, WA
[/IMG]
It's not the fuel shut-off valve, is it?
hydrotroop
bossier city
had fuel pump rebuilt due to the fact of no fuel coming out of injector lines when i turned it over had injector pump rebuilt and after bleeding lines good it runs once again thanks for help from everyone here
