Anyone ever modify and 3Pt hitch to accpet a tilt cylinder??
BotaTrac
Kubota B25D, Kubota L305DT, Kubota L2501D, Ford 681 Select-O-Speed
Mar 16, 2017
102
Hogwarts Academy
Looking for advice: I have a L2501 and want to install a tilt cylinder. Bare is a dealer only distributor and Fit-Rite is 20 weeks out according to his website. Any alternatives? I need a swivel ball on lift end and a (clevis) fork on the hitch side. Why can't I just drill in and then weld on a stud to accept a swivel ball on the hitch?...then I could use a wide array of hydraulic cylinders.
Thoughts?
Where am I going wrong here?
Thanks in advance!
CapnDean
L6060,ZD1211
Feb 22, 2018
184
Gulfport, MS USA
I have a tilt cylinder that was on my 2014 Kubota L3901. It is ball and socket on each end just like the top link is. Do you have a rear remote on your 2501?
Oct 8, 2014
623
oregon
Assuming you have rear remotes you can order a cylinder with swivel and fork ends. Search my user name and you will find some threads about this. I used bailing wire to 'template' the hose length and routing I wanted. Try Surplus Center for the cylinder.
hope to float
L3450
Feb 18, 2018
474
61
Ireland
There was a post a while ago here where someone used the two rams from an outboard engine to achieve this
