Anybody ever sharpened a piranha tooth bar?
bambam31
L3800HST 4x4,R1,FEL, 6'disc, 5'bush hog,piranhaTB,6'grader,6'rake, 48"forks
Apr 3, 2014
323
Mobile, AL
After 10 + years it’s time to sharpen it up. I have an angle grinder. What kind of disc should I use?
5,111
I used to use the “El Cheapo” disks until I tried these.
They cut so fast, I was amazed.
I also tried this version, and I liked them as well…..Much better than the “El Cheapos”.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,740
2,309
WestTn/NoMs
2,927
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
824
807
Amsterdam, NY
I don't do a lot of metal grinding so I just get a 10-pack from HF for $17.
At less than $2 / disk I don't mind blowing through a few on a job or two.
BruceMc
BX25D LX2620
Sep 27, 2014
54
122
Fairbanks, AK
I've done mine a couple of times with your basic flap disc. Start on the bottom, then hit the top. Don't grind it too shallow or it won't hold an edge for long.
fmgsr
Kubota, LX2620 - Kubota BX2380 (retired)
Dec 19, 2018
88
46
PA
Make sure you don't grind to much at a time,
and keep it cool, you don't want to change it's hardness.
