Any idea?
kcs 61
B2650 , BH77,FDR1660, PFL2042,RCR1860,RB1672, RTR1258,BB1260
Apr 8, 2024
40
19
Va
I was driving over a 6x6 and turning the steering wheel to avoid a swing set be hide. And this happened
kcs 61
Apr 8, 2024
40
19
Va
Look
Just like the other side It was straight
4,837
It’s a little hard to tell, but it looks like the left front tire (the one on the right side of the picture) is off the rim at the inside top. Not quite clear if the wheel is leaning out at the top or if it’s just the tire.
kcs 61
Apr 8, 2024
40
19
Va
Tire pressure is good. It is leaning out at the top. Tire is on the rim fine. Sorry about the bad picture
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,565
1,804
Near Lancaster, PA, USA
It looks like you parked it on a spot that isn't level and the front axle pivoted slightly. When you say "this happened", what is "this"? The front axle won't bend. Is the wheel bent?
kcs 61
Apr 8, 2024
40
19
Va
No I don’t think the wheel is bent. I’ll check it tomorrow and give an up date I didn’t know if I bent a spindle or a bearing was bad. I only have 290 hours on it
8,718
There is nothing wrong with it.
You didn't bend or break anything.
The front tires tilt in on top, and you have the front axle at an angel which makes it look even more tilted in.
kcs 61
Apr 8, 2024
40
19
Va
Ok awesome thanks for all the help. That relieves a lot. Though I was going to have to call my dealer on Monday. Thanks for all the help
