anti scale wheel bolts...
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,299
817
under a rock
anyone have the part # for the anti scalp wheels on a 60" MMM deck?
if not I'll look it up later..... thanks
11,014
You do know that Kubota makes mutiple different models of mower decks, and those mutiple different decks have mutiple different parts attached to them. ;)
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
1,011
954
Amsterdam, NY
I checked before posting - Kubota-Pad has two different 60" deck models listed under "Options" for the BX23S, both had the same bolt # for the wheels. If you're using a model that's different than what's listed you will need to verify.
John T
May 5, 2017
1,299
817
under a rock
K5221-72672
According to Kubota-Pad
Thank you.
I went with the "knock off" Amazon bolts .... $17 for 2
reviews are mixed...
I only need 1 on the front... I'll probably put it on the back and use the stock 'Bota bolt in the front.
The front seems to get the most abuse... mostly reckless mowing... :LOL:
But it's been 9 years and I only broke 1 .... so far.
11,014
And you assumed he wanted it for a BX23S. :unsure:
You know that most of us orange blooded folks have mutiple units. :p
Bee-Positive
Nov 16, 2022
1,011
954
Amsterdam, NY
Very true for sure...
I've been wrong SO MANY times now (as you know better than most) I figured I'd roll the dice yet again. Bound to get one right one of these days. šŸ™ƒ
