bambam31
L3800HST 4x4,R1,FEL, 6'disc, 5'bush hog,piranhaTB,6'grader,6'rake, 48"forks
I've had my LED lights for about 9 months and I just got around to installing them. I decided to run them directly to the battery instead of tying into the factory work light wires. I ended up having a lot of excess wire form the harness I purchased. After some use, I may end up moving some things around so I didn't want to short myself from the get go.
I can't weld so I mounted the lights to a treated 1"x6" and painted it black.
[/url]Untitled
I ran the excess wiring to the back of the mounting plate because I lave a lot of limbs that impact the ROPS and the underside of the canopy. Lots of tight spaces at the camp.
[/url]Untitled
I mounted the switch, relay and fuse under the dash. I may end up cutting a hole for the switch in the future.
Untitled
[/url]Untitled
[/url]
Untitled
