I have a B7200 w loader that just started stalling after revving the engine. The idle also is lower than normal and engine frequently stalls while at idle. While going up a slight grade in 2nd gear with a load the engine loses power and will stall. When I shift to low range power is regained, engine doesn't stall. While driving on a flat the engine runs fine in all gears. Is this an injector problem? If so, how can I address it?
Also, is there a way to test the strength and quality of the clutch?
I've had this machine for decades..it can run circles around my JD 4010!
Appreciate any helpful ideas!
