Almost (better than??) OEM Remotes
7,223
It looks awesome! Have you used it in the field yet?
Thank you. Untested as yet. Still have a couple minor obstructions to deal with before I can get it mounted and hook it in. Not expecting any problems but you never know. I have some other obligations a little higher on the food chain to take care of first but hopefully within the week. I am anxious to see it in operation. I have burned a lot of CPU cycles with Autocad getting it to this point.
Rutland
L3901, Grasshopper 725D
Nov 26, 2021
I have a L3901 and would possibly be interested if you consider selling them. I was thinking of adding quick connects to the spool valves and mounting it in the back, then running push pull cables to the factory lever location. Yours looks simpler/cleaner and I like that it has the 3rd function built in as well. Great work!
7,223
Thank you. Once I have all of the details worked out they will be available for purchase and considerably less than OEM.
Cable operated was an option I considered but the cable parts are crazy expensive and cost more than the valves.
