AG front tires already overloaded before lifting something?
Mister
130
Northwest
I have AG tires front and rear on my MX5800. I have lifted some heavy loads, up to about the capacity of the front loader, which is about 3,000 lbs I believe. Never had a problem. The tires might bulge a bit, but I haven't had problems.
Now I notice the side walls say each tire has a max capacity of 1,300 lbs, and that includes the weight of the tractor. So if that's really the case, then AG tires are already overloaded with just a front loader installed. Pick something up and you're way over the limit.
I'm guessing there must be more to these figures, and all is well, but wanted your take on it.
BigG
Sep 14, 2018
1,951
767
West Central,FL
What is the brand and size of the tires on the tractor? Does the MX5800 come standard with AG tires? I would think so but wanted to know.
Mister
130
Northwest
Fronts are Good Year. 9.5-16. You typically indicate what tire type you want when you order your tractor
SidecarFlip
Banned
550
I doubt it's an issue and you loader might do 3K at the pivot point but I doubt 3K out on an anything.
Palmettokat
M6800, B2710, L6060, Volvo 5 ton excavator and implements.
Apr 21, 2020
251
53
South Carolina
Did you buy the tractor and it with loader on it and those tires? Or have the tires been replaced or the loader added? My experience though limited when you say what kind of tires you want I have never been ask what load capacity. It a new package would ask dealer on those numbers.
BigG
Sep 14, 2018
1,951
767
West Central,FL
I am no engineer but let me try to explain this so that some of the worry is out of your mind.
1) weight of the tractor from the brochure 3734
2) weight of the bucket from the brochure 320
3) weight of the loader guessing 1000
4) max weight at the loader pins
from the brochure minus the
weight of the bucket 2275 - 320 = 1955
5) Approximate weight 6689
6) weight distribution should be 40% front 2676 / 2 = 1338 per tire
7) weight distribution 60% rear 4013 / 2 = 2007 per tire
The rating on the tire is 1300 pounds and the rear is 4000(?) pounds per tire so as you add ballast to rear of the tractor the weight on the front will become less. At the same time as you load the bucket the weight will shift some of the weight back to the front. This is why ballasting your tractor when using the front end loader is so important. What you hang out the rear counters the weight that the bucket adds.
As long as the correct ballast is used when you are lifting with the front end loader you should not over load the tires.
The real world weights will be different but I was trying to illustrate to you that you should be good with your tires. Not all of the weight that goes to the bucket goes onto your front tires.
Mister
130
Northwest
Very good points. I run ballast in the rear tires, plus often times the backhoe attachment or a plow or grader scraper
mikester
M59 TLB
Oct 21, 2017
3,191
1,676
www.divergentstuff.ca
Sorry but I'm confused by this...you are saying that adding ballast to the back tires make the front end see less weight? Is this some alternate Marvel universe with negative gravity taking effect?
Your tractor is like a see-saw. The bucket is one seat of the see-saw, the rear tires are like the opposite seat, and the front axel is the pivot. Adding more weight to the one seat let you lift more weight on the other seat. Your fulcrum sees more weight the more you add to either seat.
4,500
The see-saw is not really the example.
It's like having a plank on two saw horses 8' apart and extended 3' beyond the saw horses on each end. Put weight on one end of the plank and there is less pressure on the opposite end. The saw horse (front or rear axle) that has the weight behind it allows less pressure on the other end. The pressure removed from the front is added to the back, in this example. Put a counter weight 3' behind the rear axle lightens the load on the front axle.
BigG
Sep 14, 2018
1,951
767
West Central,FL
The purpose of the ballast on the rear of the tractor is to make the strongest axle the fulcrum. When you hang the the weight behind the rear axle the force is redirected upward at the front of the tractor.
The rear axle should be bearing the greatest part of the weight. The rear axle is the strongest and needs the most traction when doing loader work.
When you correctly balance a tractor the weight in most instances should be 40% on the front axle and 60% to the rear axle. The weight is not split 50-50 just because there is weight above both axles. Where the weight sits along the length of the tractor is also important.
BAP
Dec 31, 2012
2,558
687
What ply rating are the tires? For most tire sizes, you can buy heavier ply rated tires which will give you a heavier load rating.
200mph
Mar 3, 2017
1,228
60
PA
FYI...
According to the wholegoods price list 9.5-16 is the stock front size for the MX5800.
Copy and paste from wholegoods document:
AMXR8860A F-TIRE 9.5-16 R1 Gdyr Dura Torque 6stud
According to the info found in Goodyears tire specification the 1,390lbs is the max load rating and consistent with what the OP stated. I didn't see where Goodyear made this tire model with a greater ply rating. Other manufactures do.
8-ply rating is only rated to 1,710 lbs. Even this is marginal for this application.
The 12-16.5 R-4's for this tractor have a load rating of 5,600lbs.
5,366
One point to make is that a FEL is attached and the fulcrum point is the the center (or thereabouts) and thus adds only of a portion of it and it's loads weight to the front axle, the rest is handled by the rear axle and tires.
mikester
M59 TLB
Oct 21, 2017
3,191
1,676
I'm simple minded and pictures work better than words. How about drawing me a free body diagram. Show your reaction forces. Do a FBD with and without a load in the bucket.
Palmettokat
Apr 21, 2020
251
53
South Carolina
Lets make this thread interesting....find out the load limit for your front axle. Per a friend who owns some dealerships with one brand being Kubota pointed that out on another forum a while back. Know him to well for him not to be correct in such a comment. He did not say what brand or brands or models he was talking about.
bx tractorjoe
Jun 3, 2020
258
140
loxahatchee flordia
Thats odd.. the goodyear r14 tires on my 2501 are rated for 1870 pounds at 44 psi, while going 25 mph.. they are 8 ply..
Seems like better tires are on your list
Sorry for the upside down picture
Missouribound
Jun 17, 2014
646
38
Missouri
Adding ballast to the tires only helps stability and traction.
You need a counterweight to take the load off of the front tires.
Tire ballast only increases the weight on the front when you use the loader, not reduce it.
Get the manual for your tractor. It tells you how much counterweight you should be using for various types and capacity of loaders.
2,423
Granted, a counter weight takes load off the front axle. But how much?
I am guessing the ratio is 2:1 or greater reduction. So if you had a 1000 pound counter weight, you would take 500 pounds (or less) off the front axle. But the loader weight is hanging out about the same distance in front of the front axle. So the front axle will feel more weight than what is in the loader bucket (due to leverage), right? So the net affect is not as easy to determine.
So it seems that without mathematical analysis, each front tire will see a reduction of about 25% of the counter weight weight, or about 250 pounds per tire, for a thousand pounds on the back.
The counter weight has a MUCH greater effect to keep the rear wheels on the ground, since this calculation uses the front axle as the pivot point.
Just pointing out a difference. Not sure counter weights make that much practical difference as far as front axle loading goes, but they do certainly make a great difference in tractor stability when using the loader.
SidecarFlip
Banned
550
My front's are ALWAYS overloaded when I'm toting around round bales or moving loaded pallets of fertilizer. Never been an issue and I don't ever expect it to be. I keep them inflated to the maximum sidewall pressure and it's road speeds that kill overloaded tires (heat) and that ain't happening with either tractor.
