Aftermarket step for the Kubota B2601
Bonanza 2026
23
47
NC
The is a user report on the installation of an aftermarket step for the Kubota B2601.
Parts:
  • Step 6A70051350 aftermarket from ebay
Listed under E-6A70051350 LH Step for Kubota from eparts.shop
Price was $63 versus $161 for the OEM version.
No bolts are included - you need to find your own.
  • 4 x M8-1.25 16mm hex bolts with locking washer and nuts - stainless steel
Obtained from amazon for $26
Listed under M8-1.25 Flange Bolt & Nut (16/20/25/30/35mm) Kit Stainless 192Pcs
Had already:
10 mm wrench or socket
13 mm wrench or socket
It was a very quick and easy job to add a step to the B2601. I decided to use an aftermarket step vs an OEM one mainly because of price.
Taking off the rubber floor mat and finding the 4 bolt holes that are already there was a breeze. Place the 4 bolts and tightened them with some wrenches.
It was as easy an upgrade as anyone could ask for. No drilling needed. The part did say it was made in Turkey. Feels beefy enough for average use.
IMG_8092.jpeg IMG_8089.jpeg IMG_8094.jpeg IMG_8088.jpeg IMG_8093.jpeg IMG_8090.jpeg
5,576
Looks pretty nice, and saving a hundred bones is definitely a "bonus"....Nice write up sir! 👏
robin416
B2401
Apr 30, 2021
25
Alabama
Once again, I have no mounting holes on the upright, left on the deck. The only way to install that step is for me to drill holes in the deck. Which I don't want to do.
I'll try to get a decent pic of what I have to work with.
Trust me, I was all excited the first time I saw the video and step. That's until I looked and saw it wouldn't mount.
robin416
B2401
Apr 30, 2021
25
Alabama
I need to apologize and go bury my head. I did a huge typo, I have a 2401. I can't find a step for it either.
Bonanza 2026
23
47
NC
Why are you afraid to drill a hole in the deck? If you attach a bucket bar like a piranha tooth bar you have to drill holes in the bucket and it's thicker than the deck is. Isn't the 2401 the same chassis as the 2601 just manual drive? The after market or OEM should work. You just need the 4 holes and some bolts.
Maybe go to the nearest dealer and see if the driver's left side is the same on both models (with the exception of the holes) and if so, drill your own. The holes under the brakes would be easy. The other side, there were two holes on a vertical tab that hangs down from the deck. Maybe you have those holes, just not the 2 under the brake pedals.
robin416
B2401
Apr 30, 2021
25
Alabama
Mainly because I'm a 76 year old woman. I don't have a drill big enough to handle that kind of drilling. And I don't want to break the paint.
