Advice on trailer for BX23S
NHSleddog
B2650
Dec 19, 2019
2,144
1,839
Southern, NH
Are you just towing it home a few miles from the dealer? Get the smallest that will fit. Any old ramps will work.
Are you going to be towing all the time? Figure out the longest trailer you THINK you need and then add 2 more feet. Save yourself from buying/upgrading several trailers. Get a tilt deck trailer and AVOID ramps all-together. - JMHO
BX23-S,57 A-C D-14,
6,310
Since you can weld , I suggest making your own,especially if it's 'only' for hauling the BX23S. You can make a nice light, all steel, tandem axle trailer that's narrower than a 'car hauler' and shave a good chunk of weight off. A 'specific built' trailer means nobody will want to borrow it,overload it with an old pickup, then breakdown on the road and you get 'the call'.....
You'll have to check with local guv about 'homebuilt' trailers for specs ,like lights, brakes, etc.
I was going to build one 6x16 but neighbour bought a B2601 and a trailer, says I can borrow anytime !
