Orange1forme
In my B2650 there is a fuse block with unused fuse spots but no power to them. Power comes in via wire and then connects to the metal bar that links between each slot on that supply feed.
Is there a way to connect to this bar?
I know I can add an additional fuse block/power distribution point, which I have done for the rear accessories, but would like to be able to utilize the empty spots.
It is possible that the wire is sized for the factory loads and adding to it could overload that supply wire, I get that. For now it is just some LED lights and I would keep the load in mind before adding much, if anything, else.
