L LDB New member Equipment B 7800 HST Nov 29, 2010 24 0 1 Schaumburg, IL Jan 10, 2011 #1 I am thinking about adding a 3pt log splitter. Can I tap into the rear hydraulics (If so, how and where?) to power it or do I need to get a splitter with with it's own hydraulic pump driven by the PTO?
Bulldog Well-known member Equipment M 9000 DTC, L 3000 DT Mar 30, 2010 5,440 76 48 Rocky Face, Georgia Jan 10, 2011 #2 Do you have a loader on your tractor? If so adding remotes is very simple.
Babyfat New member Jun 24, 2010 111 3 0 Grass Lake, MI www.dakins.com Jan 11, 2011 #3 What tractor do you have? Go with separate pump the tractors pump volume is to low and your splitter will run very slow.
L LDB New member Equipment B 7800 HST Nov 29, 2010 24 0 1 Schaumburg, IL Jan 11, 2011 #4 Bulldog: Yes I have a loader Babyfat: I was thinking that may be the case. I was trying to minimize the initial cost associated with the additional hydraulics. Any recommendations as to manufacturer?
Babyfat New member Jun 24, 2010 111 3 0 Grass Lake, MI www.dakins.com Jan 11, 2011 #5 http://www.timberwolfcorp.com/log_splitters/
I IC-Smoke New member Equipment B2400, ZD28, BX24 Dec 16, 2010 66 0 0 Pittsford, MI Jan 11, 2011 #6 It would help out if we knew what tractor this is on....
L LDB New member Equipment B 7800 HST Nov 29, 2010 24 0 1 Schaumburg, IL Jan 12, 2011 #7 Sorry. It would go on a B7800 with a LA402 loader
