Adding 3rd function valve to FEL and BH
fendley
L3901, LA525, BH77, SVL65-2
Dec 31, 2016
120
St Marys, GA, USA
After searching this forum and the web in general, I have been unable to find the Kubota part numbers for kits to add a 3rd function valve to the FEL and BH. Eventually I would like to add a grapple implement for the front, and a thumb for the BH. So this leads to 2 questions:
1) Are there Kubota kits / part numbers for these? I have found several aftermarket solutions ranging from $600 - $1000, but would like to compare/contrast to the Kubota version.
2) I assume I will be daisy-chaining via the existing PF ports, my hydraulic plan is to go from the pump to FEL to 3 fx vlv to BH to 3 fx vlv to tank. Does this make sense? Alternate / better ways to do this?
bearskinner
Sep 1, 2014
926
241
N. Idaho
I think once you get a Grapple, you may not want to bother with a hydraulic thumb on the BH. The Grapple on my little BX is so strong, and so much easier and faster to work with, there's no use going to s much smaller hoe thumb. Unless you are placing heavy rocks for a living, the Grapple is awesome
scdeerslayer
MX5200DT
May 23, 2016
434
SC
Contact your dealer for a kubota kit. They're probably about the same price.
As far as the backhoe thumb, I don't really know if you want to dig into the backhoe hydraulics, they seem to be a lot more complicated. I wouldn't use a 3rd function kit, maybe a diverter, or a separate joystick valve. Another idea for the backhoe thumb is what I'm planning - tee into the bucket curl lines and put an open/closed solenoid valve on the cylinder side line. I've seen a couple of guys on TBN that did that and one has a video on youtube of how it worked. When the valve is closed, the bucket works as normal. When the valve is open, the bucket and thumb work together like a claw grapple. You've got some wiring to run but a lot less to deal with on the hydraulic side. Either way though is a lot cheaper than a factory hydraulic thumb kit.
fendley
Dec 31, 2016
120
St Marys, GA, USA
Interesting. I'll head over to TBN and look for that. When the valve is closed, is the thumb all the way back against the boom?
OldeEnglish
Jul 13, 2014
768
Western, MA
Do you have one of those fold down thumbs on your BH? If so I don't understand why the need for it to be hydraulically operated?
scdeerslayer
MX5200DT
May 23, 2016
434
SC
The factory thumb pivots on the same pin as the bucket, they use a longer pin. I've got the factory thumb with the telescoping linkage.
There are also aftermarket thumbs that attach to the dipperstick near the bucket.
That welded gusset is for the other end of the hydraulic cylinder.
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
464
363
Lake Almanor, Ca
This is how I installed my thumb...I use that thing almost every time I am on the tractor. Bought it with the manual...figured out fast that was a hassle...installed this and the rear remotes for thumb and TnT for box blade...
I was going to install the front grapple set up with third function valve on front bucket...just haven't got the thing done yet....
kenmac
B26 with hyd. thumb and 4 in 1 loader bucket and EA Grapple, but not the wicked
Dec 14, 2015
92
9
Pell City, Al.
Best decision I ever made concerning any tractor was having my B26 equipped with third function valve on FEL and hydraulic thumb on BH. The dealer had never equipped a B26 like this, but was able to get all parts to do so, I assume from Kubota. Third function is electric but thumb is hydraulic valve added to valve block. Foot pedal actuates thumb and it works very well. Worth every penny for what I do, which is mostly removing privet hedges and recovering overgrown fence lines, etc. I highly recommend both additions.:):)
fendley
Dec 31, 2016
120
St Marys, GA, USA
Any idea what the parts numbers are, so I can ask my dealer?
Is the foot pedal only for the thumb? My BH77 has no foot pedal.
