Accident To Share
WAS BANNED FOR NSFW PICS
5,160
Forget all that other B.S……. Was she cute? Clothed? Got pics?
She was in her 50's. She was dressed for the weather, but if they hadn't gotten her out by the morning, she would have been in very poor condition. No pictures, but it was in the local newspaper, but I didn't see the article.
9,116
I was doing some routine maintenance on my zero turn. Was replacing the deck belt. I had to push the pull in and roll the belt over the tension pully. Well the belt rolled and grabbed my thumb in the process.
I was stuck with my thumb wedged between the pully and belt.
Thankfully my wife was home. I was able to yell and get her put there to help me. She had to climb under the zero turn. Put her foot on the tension pull and give it a good shove so I could get loose.
6,198
You have a Great Wife (and Dad)… Let them know that MOWING is one of the most-hazardous operations. In the last 5 or 6 years in this county…. someone has been knocked-off their tractor by a low branch or loss-of-balance for some reason… and fallen off the seat and shredded by their own mower or tangled into the driveshaft. :eek:
That’s very true. Just too dangerous to be sitting nearby. And it’s one of the reasons I like the seatbelt on the Kubota. I always wear the seatbelt when mowing even if it’s on flat ground away from trees. Seeing the results of a couple of those fell/knocked off tractor incidents will make you put on the seatbelt.
9,116
" Being in a hurry and thinking more about the next three things I had to do instead of concentrating on what I was doing. Forgot to block the trailer wheels but fortunately also didn’t disconnect the safety chains. As soon as the hitch cleared the ball it jumped back about 6” as it attempted a solo run down the slope it was on. "
Every time I move one of my trailers on my NON flat @#@#$# property......... I have to hitch and lock the ball ....and hook a chain up......
several times when drop the 3 point and UNHOOK the ball the trailer will roll a bit - and the chain does a great job until I can chock the tires......... yes - I did have one run away from me, damn I hurt myself catching up to it.
I always train the newbies at work to leave the safety chains hooked up on any of our pieces of equipment when dropping them on customer sites.
Especially when it's questionable whether the equipment is gonna stay put or not.
We had a former employee drop off a piece of equipment in a customers lay down yard. He unhooked the chains, popped the latch and started jacking up the tongue. Equipment took off down a hill. Destroyed about $2,000 worth of pipe.
I rolled up about 20 minutes after he left the site and found the equipment sitting in a stack of pipe. He just drove off and pleaded ignorant.
I called the boss and sent him pictures so he could address the issue with the customer.
3,380
...luckily I had my cell phone in my pocket and was able call for help. Help arrived within 20 minutes... Had I not had my phone, which I don't always do, I would have been fastened there for several hours.
This is the most important message I got from your post. Thanks for sharing and glad it was not more serious.
About 4 years ago I was working on a plank about 11 feet up, at the house next door that I have been renovating forever, and due to a poor decision, ended up doing a face plant on the hard driveway below. Broke my left heel and could not walk, could not see well without my glasses that turned up later missing one lens and bent badly...
Fortunately I had my phone in my pocket and could call the wife for a ride to the ER. Otherwise I guess I could have crawled 400 feet to the house...
Message is, if you have a cell phone try to carry it with you when you are working. Never know when you might need it. It could even turn out to be a life saver.
Whatscooking
Grand L 3130. BX2360. RTV900. GRASSHOPPER 721D
May 19, 2021
124
67
Indiana
I worked with a guy that was unhooking what i call a rotary hoe. He was accident prone type but some how it got away from him and drove a spike though his foot pinning him.
3,481
Cell phone is something I should probably start carrying.
Was in the Buttercup dunes years ago driving Lil Foot & stopped for a break. While sipping a cold one, (not alcoholic) I heard a faint horn tooting, 3 toots, then a pause, then 3 more. Kept repeating.
Sounded like an SOS to me.
We could not readily figure out where it was coming from, but a few forays to the compass points and we zeroed in on it.
Turns out it was an older gentleman on a large quad, riding alone, who had somehow rolled off the side of a bowl & down to the bottom, where the quad landed on top of him. He was not hurt badly, just bumps & bruises, but he was pinned in an awkward position and could not lift the quad.
HE COULD REACH THE HORN.
Without the horn, I'm not sure what would have happened or how long he would have lain there, but the incident impressed me with the need for a loud, functioning horn on all my vehicles.
fj40dave
Sep 24, 2009
425
257
Yelm, WA
"What If"
I ask myself that before I do most things.....(most of the time) :)
Glad it was just a metatarsal.....heck, you got a bunch more in there....no prob!
JP_Austin
2021 Kubota M4D-071
Feb 15, 2022
34
19
Austin TX
Thanks for the story. I can not remove my grapple like yours is shown. If I tried to remove it with the quick attach it would rock backwards. I have to remove mine like in this video where it's open and there is no chance of the arms dropping off.
BA76
MX5400 Tractor, RB3784 Rear Blade, RCF2072 Brush Mower, FDR1672 Finish Mower
Dec 21, 2020
85
106
Illinois
That was a good video. I have always closed my grapple lid for removal of the attachment. After watching the video, I intend to try that method. Having the cylinders fully retracted also helps protect them from moisture. Thanks for sharing and have a good day!
