92 B7100HST- lift cylinder ring
hodge
Nov 19, 2010
2,963
531
Love, VA
I'm struggling to find a 3 point lift cylinder ring to order. A friend has a 92 B7100HST, and the 3 point won't stay up. It drifts down quickly, in a matter of a minute. Anybody have a part number?
hodge
Nov 19, 2010
2,963
531
Love, VA
7,320
I found that diagram, as well as some on German-Blisse. When I look up the part numbers, they show as O-rings. Isn't the seal ring for the piston square? The one that I replaced on a Ford tractor was.
It looks like 190, part #67211-36420, would be it, but it's called a support or back up ring- and it doesn't look right.
This is a Kubota tractor not an old Ford and that is the Kubota parts diagram. The B7100 cylinder uses a standard rubber oring and a backup ring. You need both and they need to be installed in the correct order.
hodge
Nov 19, 2010
2,963
531
Love, VA
Thank you.
Caden
1979 B7100
Apr 16, 2026
291
157
Get the O ring that goes on the cap plate also. (plate with 4 bolts)
I did not buy one (ignorance) and found that it is an odd size. My O ring assortment did not have one that was quite right.
The cylinder ring is rounded, yes. A very thick O ring.
