7800 axel
mark123
trenton
my father accidently dropped a small screw drive into the axle trying to check the level, no I am trying to pull the right tire off and get to it. I have the tire off and the castle nut holding the rod together. I was wondering if I could undo those four bolts holding the spindle and everything to the axle housing and get to the inside of the housing? Thanks
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,136
135
Hardisty, Alberta
Is the screw in the center housing? If so you can just take the four bolts you mentioned out and remove the spindle assembly. The drive shaft inside the center housing will then pull out and you should be able to get your screw out!:D The spindle is sealed to the center section with an oring, it should be alright to reuse it. You should be able to get the spindle assembly off without removing the tie rod end.
Ed
eserv
May 27, 2009
2,136
135
Hardisty, Alberta
Wheel nuts are 60 ftlbs. I have never torqued the other bolts but I looked it up, manual says 56- 66 ftlbs. hope this helps!
Ed
mark123
trenton
for a new topic, dont know if it has to do with the front end or not, but waht could make the tractor sound like a european siren? It does it in 4H and 2H. thanks
eserv
May 27, 2009
2,136
135
Hardisty, Alberta
I answered that in your other post, That is a common complain on the b7800 and similar tractors.
Ed
