72”Rear Finish mower
kcs 61
B2650 , BH77,FDR1660, PFL2042,RCR1860,RB1672, RTR1258,BB1260
Apr 8, 2024
Va
Would a B2650 pull a 72” finish mower ok. I’ve got a 60” and was thinking about upgrading to a72”
Mitjam
Jan 14, 2013
319
371
Edmonton, Alberta, Canada
I had a 72 inch when I had my b2650 with cab. It did ok. If you’re not letting the grass get to tall or running mulching blades you will be good to go 👍. I just found on any hills and running the a/c made it snort a bit lol
Flintknapper
L2350DT
May 3, 2022
1,865
2,348
Deep East Texas
I run a 72" on my L2350 (similar PTO hp) and it does fine.
As @Mitjam points out.....don't let the grass get too high. I do run mulching blades but keep them sharp. Also, I am mowing pasture grasses (tougher than lawn grasses) and have no problem.
I will say that going uphill in certain areas.... definitely gets the governor to kick in. But my mower weighs 620 lbs.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,331
1,528
Near Lancaster, PA, USA
I've mentioned in other posts that the weight of the RFM is a big factor. At one time I had two different five foot RFM's on two different tractors. A lightweight 60" on the 16HP Ford and a heavy 60" on a 21HP Kubota. Both setups worked OK, paired that way. Out of curiosity I swapped the decks. Poor little Ford had a really tough time and prolonged use of the heavier deck would've killed it. The Kubota had a great time with the lighter deck. It seemed the Kubota barely noticed the mower it was pulling.
kcs 61
Apr 8, 2024
Va
Ok thanks for all the advice. I haven’t made my mind up to get a 72” mower. I run A 60”
Now and does fine. Thanks again for all the advice
Old Machinist
May 27, 2024
259
267
NE FL
I ran a 72" behind my John Deere 855 that also had 19 PTO HP. No problems.
ferguson
L3130
Jan 19, 2022
297
116
w.v.
Run a 72" behind my 1952 ferguson TO 20 there only 20HP can mowe in third gear 2nd if grass is high your 2650 will do fine
