60” mower guard removal?
John T
2017 BX23S
May 5, 2017
811
285
under a rock
All guards removed....
Much happier.
- just saying
John T
2017 BX23S
May 5, 2017
811
285
under a rock
PS:
Getting ready to smoke some ribs tomorrow....
greeno
B2710 w/LA402 FEL, BL4690 hoe, RB1560, GS1560, Haban 5' sickle bar, 5' JD RC
Jul 14, 2018
187
Big Lake MN
Pull the guard off my lawn mower once. Put a dime-sized hole in my 27' pool liner. Promptly put the guard back on, after fixing the leak in my pool.
Be careful!
Dunbar
L2501 LA525 QA PFL2042 Forks RCR1860 FDR1672 BB1560 EA55 WR Grapple FitRite TnT
Aug 2, 2018
215
Yes your tractor will explode violently on startup like in the old movies when a vehicle went over the cliff and explodes a few feet before impact. You are certainly doomed and the IRS will kick down your door and impound your dogs. Don't mess with the nanny state!
thebicman
B2601 + BX2755HD + 50" box blade
Feb 2, 2017
333
97
Ottawa, ontario
I can see why you would remove the belt guards, gets clogged with grass. But why would you remove the side discharge chute? What I did on my old mower and will do to my new zero turn is drill a small hole in the guard. Then I hold it up if needed with a bungy cord. Won't take the chance of mowing over a rock and hitting something or someone.
rjcorazza
Mar 9, 2016
778
24
Hyattstown, MD
I removed the chute and belt guards on both of my zd mowers also. The bungee cord is a pretty common thing, and is what I did before installing an after market chute blocker.
The chute blockers are great for mulching leaves in the fall.
Sent from my iPad using Tapatalk Pro
Utopia Texas
Kubota B2650/Kubota L6060
Jun 14, 2017
110
Brookshire & Cat Spring, Texas
Better keep all the gaurds in case you need to reinstall. Many dealerships and lawnmower repair places will refuse to work on mowers without everything installed. They are releasing themselves of law suits. I use a bungee cord on my chute. Easy on, easy off...
John T
2017 BX23S
May 5, 2017
811
285
under a rock
I did the bungee cord thing for a while but It would ocassionally come off if you brushed up against something ..... also makes it a pain in the arse if you want to take a right... off the tractor..
yeah
all the guards are hanging in the shed.
3,306
I dont know my friend but as I see it there are 2 rather large guards sitting there :D
08quadram
bx2350d; Taylor Way 48" tiller; Farm King 50" snow blower
Apr 28, 2014
289
strawberry point, ia
Put the chute back on. I took out a side window of a Jeep 2 weeks ago. That cost me $325.00. Many years ago I took out a neighbor's patio door when a rock flew across both our yards. I was just high enough to get the distance. I use a bungy and hook it to FEL bracket. It is a long on that when hooked up will just slightly lift the chute to keep it from clumping. If I then wrap it over brake pedal, it lifts it almost 90 degrees.
Belt guards are a pain. Nothing but grass collectors.
Sent from my SM-G930R4 using Tapatalk
3,306
Yep unless your putting a mulcher kit on ,please put the chute back kids pets and windows are all at risk. I also use the bungee cord and it brings the chute up level when mowing really heavy stuff.
The belt guards fell off I think about a week after I got the beast. New nuts washers lock washers and puff the were loose and off again. After about 4 times I took them off all the way, now I can clean the top of the deck inspect the belt clean the grease fittings,, easy pezzy,, and I like easy
cre73
24
Central Illinois
On one of the forums I saw one fabricated from chain welded to angle iron. I plan on copying the design. I have to keep my chute up to fit through many places on our properties.
08quadram
Apr 28, 2014
289
I have similar issues with space. That is why with the bungy, I can just pull and drive through. It has cost me with the chute up. now I only leave it up where I know there isn't anything/anyone around. (back 40).
troverman
Jun 9, 2015
1,188
275
NH
I took the grass discharge guard off the day I bought my 60" belly mower for my B-series. Much cleaner discharge. I guess if you mow in rocks you might want it on, otherwise not. I removed it from my zero turn as well.
I do keep the belt guards on...they collect grass but don't harm the belts.
K.P.
B7300, LA272 FEL, B2650, 8160 Ballast, G2460G Mower, Danuser 20/40, Woods RB60
Aug 11, 2010
84
Cary, IL
I put a 3/4" to 1" diameter X 10"-12" long piece of stick or dowel under the discharge guard up against the spring hinge. It raises the angle of the guard just enough to disperse the grass discharge a little wider, but still deflects potential projectiles.
08quadram
Apr 28, 2014
289
But, DAD !!!! :mad:
You don't want to be grounded do you? Lol. I would just hate to see somebody else have to replace windows for this reason......I speak from experience..............I do sound like my dad!
