5ft bush hog for bx2660?
hb82290
Jennings, LA
Hey guys I'm new here but I've looked around and can't really find anyone with experience running a 5 ft bush hog behind a bx2660? Does anyone know how it would handle it motor wise?
TripleR
Sep 16, 2011
1,911
SE Missouri
No, manual recommends a 42" and I run 48" which works fine. You might be able to spin it with the 2660, but I'm sure not going to put mine through it.
hb82290
Jennings, LA
The reason I ask is, a while back I got a quote for a L2501 and he priced out a 5 ft cutter. And I asked if it would have any problems running it and they said no. So I figured my 2660 might be able to handle it.
TripleR
Sep 16, 2011
1,911
SE Missouri
Just my opinion from briefly checking, but 25hp is kind of misleading, look up the engine specs on each, it looks like the BX makes its power at 3200 and the 2501 at 2200, 540 PTO is quite a bit different, doesn't show the torque curve, but the engines are a lot different.
A 5' will be a bear on handling and hitch configuration.
bcp
BX2360
Apr 20, 2011
644
78
SW WA
If it was a power problem, you could just drive slower. The problem would be the weight so far behind the hitch, size, and lift. The flex joint hitch and the smaller lift range of the BX make it harder to get the rear wheel up on something that heavy and large.
Bruce
MadMax31
BX23S, 60" MMM
Nov 5, 2014
766
New York
Youd mostly have the HP, but not the mass to handle it. The L2501 weighs nearly twice what a BX weighs. I think youd be asking for trouble, but you know your situation best...
olthumpa
L275
May 25, 2011
1,501
Maine
bx2660
Weight:1,389 lbs
Rear lift (at ends): 1,210
Rear lift (at 24"): 670
Kubota L2501
4WD Hydro Weight: 2623 lbs
Rear lift (at ends): 1918 lbs
Rear Lift (at 24"): 1389 lbs
The L2501 1413 lbs heavier
the lift at 24" is 179 lbs greater than the bx at the pin.
You are comparing apples and oranges. HP is only one factor.
7,158
We just had another one of these that came up, not sure of the real outcome of the other post, but if the implement is too large and not recommended for use on the tractor by the manual it can void the warranty.
On the the HP and usability side, an L is always going to outdo a B or a BX. ;)
bcp
BX2360
Apr 20, 2011
644
78
SW WA
Do you already have the BX and 5ft cutter? If not, don't buy one of them.
If I had a BX and had a 5ft cutter, I would leave off the top link, set minimum front height with check chains, adjust the rear a little higher, and use it as a towed mower.
Bruce
