5amp key stop fuse
mbern
L3240
Nov 11, 2013
24
Garland, Maine
I have a L3240 that quit on me this morning while pulling wood. to make a long story short it turned out to be the key stop fuse, I replaced it with another 5amp fuse and it blew so I put the spare 10amp in and it started.. sitting at my garage now but I was wondering if anybody else has had this problem?
5,161
Considering it's the 5 amp fuse, you more than likely have either, have a Stop relay or Stop relay timer that is failing, or you have a wire that is getting rubbed and shorting out.
I would bet on the relay or timer. ;)
mbern
L3240
Nov 11, 2013
24
Garland, Maine
now where can i find the timer relay? the dealer said it could be a seat switch or the parking break light switch shorting out
mbern
L3240
Nov 11, 2013
24
Garland, Maine
found the problem, one of the wires ti the safety switches under the dash was chaffed and grounding out.. A mechanic at the dealer said that its quite common..
