54" or 60" Box Blade for B2601
HomerGuy
Hello,
I have a B2601 with the 54" wide FEL bucket. Looking to purchase a box blade and I keep wavering between a 54" and a 60".
The cost difference between the two is negligible. The 54" will stick out about 3" on either side, and the 60" will stick out 6" on either side.
I like the idea of the 54" as it matches my FEL bucket and keeps the overall width the same. However, I can see the extra 3" of overhang bring handy when grading the driveway, as I can keep the tractor a little bit further from the edge.
What do you guys recommend?
Thanks!
sdk1968
B2601HSD & CK4010HST 4WD/FEL
Oct 19, 2016
929
36
i had the 60" on mine when our driveway was gravel.
liked it being just a hair wider than my rear tires.
the tractor physically handled it fine.
bx tractorjoe
Jun 3, 2020
258
140
loxahatchee flordia
I would get the 72 inch.. about 500 pounds, great for ballast and much easier to see the edge while your grading.. that and if you ever upgrade to a larger tractor it won't be to small..
Tire Biter
B 2601 434 loader MMM, bunch of tractor stuff . Ford 4600
Jul 10, 2012
237
87
S.E. TN
IDK. Box Blades usually don’t angle, unless you contort your hitch to angle it. I’ve done that. Anyway, I have a six foot yard box I use with mine. Works fine. Five foot will work on yours. When I had a five foot box, I use to put cement blocks on it when using the diggers to really get them into the ground.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,375
378
I'm on sandy/loamy soil and have built a mile of bush road with pit run and 7/8 crushed gravel. My B2620 will pull a full 60 inch no problem without traction or power loss.
HomerGuy
Thanks for all of the replies. This will be a box blade/box scraper so no angled function.
Sounds like the 60" is the way to go. Also seems to be a more common size if I ever change tractors or sell the box blade.
2,965
If you were planning to do real hard work with the box blade, I would recommend the one that matched the width of your rear tires...I have a 60 inch which works pretty well behind my B2910, but will stop the tractor in its tracks if I get too aggressive. Problem is not enough weight to maximize traction. Even with loaded rear tires and loader on.
For driveway maintenance, the 60 inch sounds perfect.
River19
B2601, RB1560, BB1260 and BX2830 blower
Sep 10, 2020
326
505
NH/VT NEK
I have both a RB1560 Rear Blade and BB1260 Box for my 2601 and I feel those are good sizes for this particular platform. Wide enough to cover the tracks......
Clearly I like 60"
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,375
378
And if you get into ground that is too much for a 60 inch and causing you to lose traction, adjust the top link, take less aggressive cuts and make an extra pass or two to do the job.
