4x4 selector leaking L6060 cabbed
Febrink
Kubota bx2200, bx2660, L6060
Apr 11, 2021
Illinois
Hey everyone, I have another question. My L6060 began leaking from around where the 4x4 lever goes into the transmission. I removed the roll pin holding what I thought was just a shifter slide over a shaft into the transmission. I removed the one bolt securing it to the transmission. I found out this part of the shaft and the shaft will only partially come out. I have the o rings to replace the old ones. I am afraid to tug to hard not knowing if it is connected inside the transmission. It is looser in two wheel drive then four wheel drive. Any advice is greatly appreciated. I was loosing fluid in a steady stream.
