4wd
Caden
1979 B7100
Apr 16, 2026
194
97
To narrow this down, does the lever move but not engage or is the lever sized?
Vikingfynbo
BX2370-mower deck-box scraper-landplane
Dec 12, 2021
98282-Washington
Lever will not move up into 4WD but moves down into 2WD feels like it is blocked or jammed. I tried moving back and forth while pulling on lever too.
Caden
1979 B7100
Apr 16, 2026
194
97
I will have to step back and let those with more knowledge take over.
But I will add that I have used the FEL (if apllicable) to pick the front wheels off the ground to get 4wd to engage before.
4,095
Viking… you are asking folks that are blind to look at your malfunctioning tractor.
You have to consider that when you ask for help.
For example,…. have you looked beneath the tractor and inspected the Linkage to that lever?
is there a stick jammed in it? Is it properly connected and routed? …or is it Bent out of shape?
The First thing us blind folks Imagine …. is the front drive-line is out-of-sync with the rear drive-line…. and is why our suggestions only consider that.’
I.E. : You need to do the simple inspection and take/share pics if you want useful help. ;)
Killer Bee
78
98
Show-Me State
does what this guy did ring a bell?
otherwise, like stated above, need more info to even make an educated guess.
is the machine new to you or had it for years, new symptom or started recently or after an event, hours on the machine, etc.??
our b8200 pto and 4wd levers rotate on the same trunnion shaft and they have interfered with each other occasionally.
good luck! 🍻
