4wd engaged wheels wont turn.
Jamsmik1
Ford 7700
Feb 8, 2023
Philippines
I have and old ford7700 i want to ask if anyone know whats wrong with my tractor. The tractor wont run when i engage 4 wheel drive. It seems like the front wheel is stuck.
KennyMillar
L1500DT Tractor with Loader
May 9, 2022
46
14
Central Scotland
Hello! Welcome to the Ornage tractor forums!
A ford you say.... What's that?
Only kidding!
Why not disengage all drive (neutral, 4WD off) and jack up each corner and see if the wheels are free and take it from there.
5,178
Only kidding!
I have had 3 Fords....
All have been great.
Still have two (+ Kubota) now.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,359
1,959
WestTn/NoMs
Just looking at the parts breakdown, it looks like you could remove the drive shaft (spindle) without too much trouble. Then, if it still pulls in 2WD but not 4WD the problem must be in the transfer case area. (My Ford is only plain-Jane)
Add: that's not going to tell. If you pull the driveshaft, will the tractor coast in 2WD and 4WD? Did this start suddenly, or had it been making warning noises?
9,109
Don't know enough about the fords to help you, You would get better answers at Tractorbynet.com
