4630 axle leaking
retiredcop
L4630GST
Jul 18, 2015
Lenoir City TN
Can the axle flange be separated from the front gear case without dismounting both from the tractor to check the oil seal? had hay twine wrapped around the flange.
rbargeron
Jul 6, 2015
1,171
238
western ma
Yes - when the cover is unbolted the axle, flange and gear come with it. (Drain fluid first - bottom plastic plug) There are two half-rings behind the gear trapping the assembly together on the axle.
I'm a new member here too - but I've been posting on TBN a long time. Here's a front axle leak thread from TBN that may be useful. Take care, Dick B
