Can the axle flange be separated from the front gear case without dismounting both from the tractor to check the oil seal? had hay twine wrapped around the flange.
Yes - when the cover is unbolted the axle, flange and gear come with it. (Drain fluid first - bottom plastic plug) There are two half-rings behind the gear trapping the assembly together on the axle.
I'm a new member here too - but I've been posting on TBN a long time. Here's a front axle leak thread from TBN that may be useful. Take care, Dick B
