3rd party accessories?
ACDII
Oct 21, 2021
678
421
Illinois
Whenever my L4060 HSTC arrives, I would like to add a down force, or whatever it is called to the 3point and a hydraulic top arm so that I can level grade, rake etc without the arms bouncing up. I asked the dealer if it has such a thing on it because it drives me nuts when trying to grade with my B2410 and it floats up and down instead of digging in to level.
I would like to add other items eventually such as suspension seat to the B2410. Are there companies that make things for Kubota tractors other than the normal implements and such?
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,410
1,691
Kalamazoo, MI
I don't think you can make your new tractor into a "down force" 3PH. Top n tilt, yes.
MtnViewRanch
796
233
Lakeside Ca.
JD 4000 series tractors are the only main line tractor that offer a 3pt with down force that I know of.
And then if you do get that feature, you supposedly can not have a hydraulic side link part of a top & tilt set. :unsure:
As far as your implements bouncing, get heavy implements and slow down some. You hitch up to a 1000lb box blade, I doubt that it will do much bouncing.
Plus, sometimes you just need to wait and do the work after a rain.
Enjoy your new tractor. :)
5,066
Yes!
In my opinion, grading should always be done after a rain!
ACDII
Oct 21, 2021
678
421
Illinois
I was trying to level out my arena with fresh limestone, some sections were a bit rough and lumpy and no matter how I attacked it, could not get them smoothed out using a 6' grader blade. Of course this was 15 years ago, and haven't done any grading work since, I gave up trying to figure it out and let the horses do the work. Those buggers did a better job smoothing it out than I ever could.
Is there a site to buy Kubota accesories and items like 3rd valve kits and such without going to a dealer for it all? Thats what I'm looking for.
mikester
M59 TLB
Oct 21, 2017
3,547
2,006
www.divergentstuff.ca
I try to support my local dealers. I want them to continue to provide timely service, parts and support.
I have two dealers about the same distance away. I can comparison shop that way.
I like the idea of finding spare parts usually on the same day I have a breakdown or service. I can call ahead and have the part ready for pickup- and I can send one of my kids to get it without worry. Win-win.
Goz63
Kubota L2501, LA525 loader, QH15,Land Pride RCR1860, BB2560, SGC0660, forks
Jun 19, 2021
299
349
Mississippi
One thing that may help is tightening the float of the 3pt. There is a knob below the front of the seat you can tighten to reduce how fast or slow the 3pt floats up and down. I apologize if you already know about it. Adjusting that and your speed usually helps I’d digging in a staying in contact with the ground. Check out the “Dave’s knows how” YouTube channel. He has a great tutorial on it.
ACDII
Oct 21, 2021
678
421
Illinois
I am more looking at aftermarket things you can't get at a dealer. Mainly for my old B2410 that Kubota never made for it.
