3rd Function Hydraulic Valve Kit
sagonate
L4060
May 20, 2016
Tiverton, RI, USA
Does anyone know if Kubota makes a 3rd function hydraulic valve kit, so that a grapple can be added to an L4060?
I can only find one sold by Everything Attachments online.
Thanks.
4,511
I'm pretty sure they do, but the best answer to your question will come from the dealer.
There is a Kubota 3rd function kit for an L4240 and it is part number L2225 and cost $893.
kenmac
B26 with hyd. thumb and 4 in 1 loader bucket and EA Grapple, but not the wicked
Dec 14, 2015
92
Pell City, Al.
I'm not certain Kubota made the kit on my B26, but the dealer installed it and I bought a Kubota 4 in 1 bucket, so I would think there is a factory kit available also.
FiremanDan
L6060 ROPS, Wicked grapple, LP RCF2772 cutter, LP BB3572 box blade
Dec 8, 2013
21
AR
They make one for my L6060. I'll see if I can find the part number on my paperwork when I get off work tomorrow. That price sounds about right.
savoy9020
G1800, L2501 (2016) 5ft LP box 2004 F250 6.0 Lariat Supercrew 2017 1140D RTV, 2
May 25, 2016
50
Savoy, Texas
If you happen to see what the kit would run for a L2501, let me know. I'm looking at getting a grapple as well. Bought a new Stihl saw yesterday, and made a big pile o cedar..
fendley
L3901, LA525, BH77, SVL65-2
Dec 31, 2016
120
St Marys, GA, USA
Idaho implements sells a 3rd function for 2501 and so does wr long about $800
After looking at all of the options I could find on the internet for my 3901, I decided on the one from Idaho Implements. The kit has arrived, but I have not yet installed it; perhaps this week.
fendley
Dec 31, 2016
120
St Marys, GA, USA
Received the kit from Idaho Implements. Ended up being $725 after shipping. This kit would be the same on the 2501 with the LA525. I have the kit installed, but as I do not have a grapple yet, I will have to report back later on its use.
fendley
Dec 31, 2016
120
St Marys, GA, USA
Borrowed my neighbor's grapple, and the 3rd function valve works great. I did have a couple of hydraulic leaks, due to me not tightening the fitting sufficiently. I am always worried that I am going to strip the nut, or cause some other issue, but tightening the two joints by 1/16 of a turn stopped the leak. The grapple works great - push the upper button and the grapple opens, and the bottom button closes the grapple.
Grizzy3901
L3901hst, la525, 72" landpride finish mower
Jan 1, 2017
67
Bealeton va
Was looking at this one also. I read the instructions on the site and they had said something about cutting a line. Did you have to do that or was it all just hydraulic fittings?
fendley
Dec 31, 2016
120
St Marys, GA, USA
Their instructions are somewhat dated; that was referring to cutting a line to tap into the tank return, which I did not have to do. I have both a loader and backhoe, so my install was to remove the PB connection that went to the backhoe and put it on the new 3rd valve "T" fitting port. The a new supplied hose went from the loader PB port to the 3rd valve "P" fitting port. The other two ports are where the lines (supplied) go forward to the disconnects. No cutting anywhere.
Other than the slightly unclear directions, this is a great kit.
southcoastlocal
MA
Do you have the Idaho implement 3rd function model # that works with the L3901 loader / backhoe, or a link for the exact kit. Thank you
fendley
Dec 31, 2016
120
St Marys, GA, USA
This is what I ordered (I have the same L3901/LA525 / BH77):
This is what I ordered:
Item Sku Qty Subtotal
Dedicated Third Function Hydraulic Valve Kit, Includes Hoses, Up To 14 GPM
Specify Loader Model. Please call 208-265-0415 for other loader options.
Kubota LA525
Please Enter Your Tractor Make/Model
kubota L3901
Does Tractor Have a Cab?
No Cab
CA-1OTKD03-CA-KULA525-CA-TRACTOR-CA-TRACTORNC 1 $688.70
Subtotal $688.70
Shipping & Handling $39.95
Grand Total $728.65
cn2redjeep
L3901, tiller, finish mower, pallet forks, rear blade
Mar 27, 2015
25
Illinois
Where did mount the control levers?
