3PTH Ballast Box
ranger4327
L3800
Apr 2, 2012
20
Northern Maine, USA
Looking to make a 3PTH ballast box for my L3800. I am thinking of using cement in some sort of form, with the 3pth encased in it. Whats the cheapest way to accomplish this? Anyone have any ideas? Thoughts, pictures?
I am thinking of purchasing some sort of 3pth, building a form of some sort, and encasing it in cement....
was looking at Northern Tools at
http://www.northerntool.com/shop/tools/product_200315619_200315619
http://www.northerntool.com/shop/tools/product_200342832_200342832
and pouring cement around them in a form....will it work?
thanks !!!
Kytim
B6000DT, B7100DT,Snowplow, RM360, Scoop, Cultivator, Carryall,Disk, plow
Aug 14, 2009
848
12
Western Ky
As far as the cheapest form material I can think of is a small steel drum like grease comes in. Or i saw one that someone had a short piece of plastic corrugated drain culvert. you could use the cardboard rediforms for pouring concrete columns and piers. braced up correctly a plywood box would be just fine and could be left on after curing too.
I'm sure there are many other great ideas out there.
ranger4327
L3800
Apr 2, 2012
20
Northern Maine, USA
Thanks Kytim.... I think I am good to go for the cement form, but any thoughts on the Draw bar and stabilizer in the links above from Northern Tool ? Just wondering if they would be rugged enuff for the weight of the cement.... Or should something else be better ?
I was just going to build a wooden form or use a plastic barrell kinda like you mentioned !!
Stumpy
L175
Dec 1, 2011
848
NE Ohio
I'd be worried about the cement cracking about the draw bar. That thing will have to endure a lot of jolting. I'd rather have it encased.
This is what Kytim is talking about. Might Dodge has pictures of his on page 2.
That thread has a lot of different options. Personally I'd go with a 55gal or 30 gal drum and weld the draw bar to it. I've seen something similar done with a metal trashcan which was then used as a ballast\salt bucket.
moderatmixed
27
Woodstock, Ontario, Canada
Kubota makes a metal box. I started down the same path as you, but by the time I priced the metal, considered the time to weld a three point hitch, etc I decided that the $200 was an acceptable price to pay. I filled it with concrete from Home Depot. I tilted the box by placing the rear on a 2x4 so when dry, the concrete top would slope from front to rear and any water would drain to the back of the box. Lastly I drilled 2 drain holes in the box to allow any water to drain off. The total weight is 480 lbs with concrete and some scrap metal that I through in to provide some structure. Too I added 2"U" bolts so as to provide lifting points. Some times it is just worth paying the price. The box has worked beautifully.
pat331
L35, mower, bushhog, cement mixer, grader, boxblade, forks, posthole digger
Mar 31, 2009
298
Ft. Worth, TX
Here is my counter weight. I haven't weighed it, but guess it weighs in at 800 to 900 lbs. I made it for at least 6 years ago and it shows no signs of cracking. I put a ball on the back to move trailers if needed. Please post pictures of your creation. Good Luck!
Stumpy
L175
Dec 1, 2011
848
NE Ohio
Filled to the top!? Jeese the front tires must float with nothing in the bucket! I surprised it can lift that thing.
Correction, 55 gallons of concrete is a max of 500lbs or less depending on density. Fill'er up!
Correction to the correction, that number above is actually in kilograms. 500kg=1100lbs
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
Do a search on here for ballast boxes, there's been all kinds of great ideas used in the past from fellow memebers!
Kytim
Aug 14, 2009
848
12
Western Ky
As has been said, there are many ways/ideas to make a ballast box. If you notice I didnt say how I would make one.
If I was making one, 1/8th or 3/16ths steel welded box with welded pins and toplink and 2" receiver hitch external D rings and chain hooks all connected. poured concrete with mixed sizes of pvc pipe placed vertical for handles and chains. a molded in chicken coup and garden gnome. naw, forget the chicken but everything else would be good.
Not necessarily cheap way to do it though but, would be very versatile. oh, dont forget the slow moving vehicle sign.
pat331
Mar 31, 2009
298
Ft. Worth, TX
My L35 handles the counterweight ok, but does groan. If my math is correct, a 55 gallon drum has a volume of appx. 0.27 cy. And a cy of concrete weighs in at 3000 lb/cy, so that figures to be about 817 lbs. plus all the steel I put in it. Maybe one of these days I can get the thing weighed. The L35 has a heavy FEL and the heavy counterweight is needed to keep the rear on the ground. I have to be careful picking up anything that maxes the FEL. The tractor is most stable with the BH on. I have water/antifreeze in the tires and would like to come up with some wheel weights to keep it grounded.
gpreuss
Oct 9, 2011
1,166
Spokane, WA
:)I used an either 22 or 27 gallon more or less rectangular plastic trash can - I think it was 22 gal. I cut it, and poked a drawbar through it, close to one end. I had half a dozen 5' pieces of re-bar that I put through the holes in the drawbar, the bent them around inside the bin. At one time I had built a third arm for my back hoe, but its bucket was once on the ground when I took off, and twisted up the cylendar to it, so I removed the arm and restored the backhoe to normal. That arm is the ugly iron piece for my 3rd point hitch attachment!
Then I mixed 6 80 lb bags of redimix concrete, and poured it in. The trash can reshaped itseld a bit rounder. I ran out of redimix, and tossed in an additional 2 bags of mortar - I think they were about 50 lbs each.
Since I took this picture I have trimmed off some of the excess steel. Pressure washing got rid of most of the white on the plastic trash can. I figure this for about 600+ pounds.
I like having this as ballast, rather than the RHINO rear blade - it is less apt to dig into the ground as I'm digging with the FEL.
searay
L3200, GMC Yukon, rotary cutter, pallet forks, box blade, post hole digger.
Dec 28, 2010
24
Courtice, Ontario, Canada
I'm located in Coutice, right next to Oshawa ON. Did you get the Kubota ballast box locally or did you have to go to the states to get it. I agree with you that $200 is reasonable for a unit thats already painted orange and I may be fussy but who wants to put an old rusted barrel on the back of a new Kubota?
