3830 fuel solenoid chatters
Bertrrr
Kubota L3830
Jul 9, 2026
Kinder , La
Machine dies after a minute or two , you can hear the fuel solenoid clicking off and on
The solenoid has been changed as well as the ignition switch , Tested the seat switch safety and eliminated that part and it still does it , pulled the fuel solenoid and verified the coils read ohms and wires are not damaged
Looking for the "OPC Timer " now as I am told this may be the problem ,
Any advise would be great , thanks
Motion
Kubota MX5100HST/FEL
Aug 17, 2020
573
332
Mandeville Louisiana
Do as you feel is best. Make sure to set the brakes. I'd start by hot wiring the solenoid straight off the battery (+) and ground straight back to the battery (-). Be reminded a loose ground can cause what you describe. You could also try jiggling the wire/harness while it's running. Good luck
Bertrrr
Kubota L3830
Jul 9, 2026
Kinder , La
I can run a hot wire to the solenoid but am being told there are 2 different circuits to the solenoid , one to pull in the coil and another to hold until stop signal
Motion
Aug 17, 2020
573
332
One wire would allow the solenoid to pull in once the safeties are satisfied, the other would stay energized to keep the engine running and of course the other is the ground. If the engine starts, then I'd suspect the seat circuit or the grounding. If you have the wiring diagram for your machine, it will help troubleshooting. Check all connections and fuses for looseness and corrosion.
10,866
It would really help if you gave us the whole model of tractor your working with, as the wiring is not the same for every model
Your issue could be wiring, solenoid, solenoid relay, or OPC timer.
The chattering sounds like a Relay issue.
