3301 power steering leak
Swando
Kubota L3301 tractor
Mar 3, 2017
35
Fairfield, Idaho
The "search this forum" tab does not work for me. I'm trying to find how to fix a leaking seal on the 3301power steering. Seal is on the main shaft which outputs to the tie rods. Looks like remove a big nut then use a puller to remove tie rod connector from splined shaft. Pop out seal and install new. Any old threads would be helpful. Thanks
5,475
100 td
Aug 29, 2015
1,776
ɹǝpunuʍop
Use this type of search in google, change the words at end for what you want and take the gaps out of the initial web address which starts with site and remove dot, leave spaces at end and between search words
site: orangetractortalks D O T com/forums/ 3301 power steering
Swando
Mar 3, 2017
35
Fairfield, Idaho
As often happens I may have misdiagnosis the problem. The power steering return line clamp was very loose. Thanks for the help!
5,475
Heck of a lot cheaper and easier fix! :D
