3 pt hitch won't go down
momark
M5660 SUHD
May 14, 2017
36
Arnold, MO USA
I purchased a new M5660SUHD in May 2017. It now has only 38 hrs. on it. I used it for a couple hrs. the other day for some fel work. I put it away and went home that evening(75 miles away). Later that night it dawned on me that I didn't let the 3ph down when I parked it. It kinda bugged me but I figured it's not a real big deal. Went back down about 3 days later(today) and put the lever down but the 3ph didn't go down. I started it and let it get to operating temp but still it wouldn't go down. So, I did some other work and came back about 4 hrs later and it was still up. So, I just left the lever down and had to go home. By the way it has a 6 ft tiller attached to the 3 ph also. Any ideas on what's going on and/or how to fix it? Any help is much appreciated.
Thanks, Mark
Gillie Dog
L2501 HST, FEL, Forks Attachment, Harrow Disc, etc.
Dec 12, 2018
79
Southern California
3 point lowering speed control adjusted all way in/seated or piece of debris in it.
Open full open, counter clockwise, and see what happens.
GD
9,137
Like GD said it's either the three drop speed control, round knob under the seat, or the three point feedback linkage is lost, off or gotten out of adjustment.
The linkage is connected to the top of the left lift arm. ;)
momark
M5660 SUHD
May 14, 2017
36
Arnold, MO USA
I already tried the speed control knob. Sorry, I forgot to mention that in my op. I will check into the linkage next time I go back, should be Wednesday.
momark
M5660 SUHD
May 14, 2017
36
Arnold, MO USA
So do you think the fact that I had left it in the raised position for 2-3 days had anything to do with it, or is that just a coincidence?
Sparky73
2018 B2650HSD
Apr 28, 2018
31
WA
Likely a coincidence below it would have bled down over time even with the control lever fully raised.
9,137
No leaving it up won't have anything to do with it not working.
If anything leaving it up and it staying up, tells you the seals on the three point lift cylinder are good! ;)
momark
M5660 SUHD
May 14, 2017
36
Arnold, MO USA
Ok, sound good. Just wanted to make sure because it's still under warranty, so didn't want to tell them the wrong thing. Hopefully I can fix it myself if it's the feedback linkage. If not, I guess I'll have to call the dealer.
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,187
170
Hardisty, Alberta
Just be careful you don't get hurt working on it if it has a load on it! often they come down when you are least expecting it!
Captain13
Feb 27, 2019
520
170
Kathleen, GA
Have you tried cycling the draft control?
5,501
2,208
Had a small M in the shop a while back similar complaint. It had draft control. Owner had a shredder hooked up to it, way too big for the tractor. At some point the draft control part of the top link broke and the draft control feedback "thought" that it was where it needed to be and the implement would not drop. Look at the linkage near the tractor top link real good. Might find something there.
wendol
L3800 HST
Feb 5, 2014
194
40
North Tx
I had this happen once.....and after much head scratching.......discovered the top link was jammed into/against the ROPS, therefore would not release until I relieved the jammed situation.
