3 point will only pick uo when?
tractorproJohn
L2850 with a BF500 Loader
Jul 28, 2019
River Oaks, TX
i have a 90ish L2850 3point will only raise when bucket on loader is in curling up positon hoses are plumbed correctly asof another 2850 if loader is removed 3 point does nothing does anyone know what could cause this i hope this thing is kicking my butt !!thanks for looking blazer
5,223
In the other thread that you started on this exact same issue I told you you need to turn the selector valve on the hydraulic block (Slotted screwdriver valve on the side of the block) to get the three point to work with the loader removed.
So go do that then report back on if the three point is working normally with the valve in the bypass position.
If it is the problem lies in the loader valve, either the detent or linkage is hanging it up and not letting it center or the spool is damaged and that is not a repairable issue, you will need to replace the loader valve.
Once you report back, I will put the two thread together to keep the confusion to a minimum!
