Paul Allwood
Kubota B7200HSTD, RC60-72H MMM, homemade FEL, forks & ballast box, rotary hoe
I'm after some advice on my 3 point hitch.
The first thing - when I move the lever to lower it fully it drops part of the way quickly, then takes a long time to drop fully.
Fully up
5 seconds after moving lever to lower fully
3 minutes after moving lever to lower fully
4 minutes after moving lever to lower fully - as low as it goes
Is this normal, or is there something I need to check, adjust or fix ?
The second issue is that while using it with the ballast box on and set to about half height it drops in height so that the bottom of the box eventually hits the ground. Is this leaking seals on the 3 point piston/cylinder ?
The 3 point speed adjustment valve appears to work (doesn't lower at all when I close it) and is set to the fully open fastest lowering rate position.
All help appreciated.
Fully up
