3 point Hydraulic problem
peterryg
Sunshine LZ1 225
May 30, 2018
australia
Iv a Sunshine ZL1-225 grey import, that l need help with regarding the 3 point linkage hydraulics. Initially the hydraulics would every now and again lower by itself, and occasionally wouldn't respond to up/down commands.
Now it dose not respond at all. Its currently in the up position. Even when l turn the Valve below the seat, it still sits in the up position. Really not sure what it could be. Any advice would be greatly appreciated
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
I'll take a punt here. Model number ZL1-2254, do you by chance mean ZL1-225?
If you do, does it have a monroematic control system on it?
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
First place I would look would be controls/switches and sensors, monroematic can automatically lift in reverse, when turning etc. Perhaps a control is set incorrectly, loose wiring, bad connections, lever in wrong position, feedback rod adjustment incorrect.
bucktail
Jun 13, 2016
1,277
198
MN
Most 3 points are single acting so if you don't have weight on it you can't get it to go down.
