3 point hitch lower speed and limit function
BarabooBob
BX2230, LA211 loader, BX2750B snowblower, RCK60B-22BX mower, 48" King Kutter
Feb 28, 2026
Baraboo, WI
I obtained a BX2230 tractor that was not properly lubricated during its earlier life. When I got it, the 3 point arms would not move unless I stood on them. After raising and lower them for about a half hour, I got them moving better. While doing this, I did not have anything to attach to the 3 point lift.
The 3 point hitch lowering speed control knob is froze and I can't turn it by hand. Is there a trick to getting it to turn such as a lock nut that I am not finding? I don't want to resort to a pipe wrench because I don't want to break anything.
I have also not figured out the lowering limit control. I have looked for it but don't know what I am looking for.
I tried to get the top link to free up but even with using my Mapp gas torch, soaking it in Kroil and using a big pipe wrench, I could not get it to loosen up. I ended up surrendering and buying a new one. I am not usually a quitter but sometimes your time is worth more than beating a piece of iron.
I have been lurking here for a while but joined yesterday. Sorry to come in with a bunch of questions.
10,521
Do not exert heavy force on the drop speed knob you will break parts.
You need to get a rust breaking lube around the rod where it goes into the case.
Treeguy13
L345DT
Oct 8, 2022
Iowa
New to me bx2380 with opposite problem. Rotating the valve all the way into closed doesn't stop or even slow the slamming down of a 3 pt implement.
How is this valve accessed and serviced?
