The plug on my threee point control valve recently blew off. I have a 2003 Kubota L4330, Does anybody know why this happened and a way I can fix it? Thanks
I was trying to lookup parts for your tractor in the hydraulic section... from the kubota site: https://apps.kubotausa.com/illustrated-parts/
There was many references from Old and New... wondering if they had some problems that they changed/fix.
Still could not figure out what part you are showing, is it the underside (photo upside down??).
Can't help much more than that...![]()
The part number of the plug is TA04036650 It should only see transmission case pressure . If you install a remote valve the "tank" tube gets connected there. Possibly the transmission vent is clogged or maybe the plug was never properly installed and finally just fell out?
